ChiefUserKPC Posted March 15, 2019 Share Posted March 15, 2019 How do you print an 18x24 sheet from Home Designer Suite 2019? Link to comment Share on other sites More sharing options...
solver Posted March 15, 2019 Share Posted March 15, 2019 A forum search/Home Designer website search should find details, but you don't -- you create a 1/2 size PDF, then double the size when printing. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 15, 2019 Share Posted March 15, 2019 In Suite you first go to "File - Print - Drawing Sheet Set Up". When there you select "18 x24" drawing sheet (if you do not have a printer that prints on 18" x 24" paper then you "print" to an 18"x24" PDF file which you then email or carry to a print shop that does have a printer/plotter that prints at scale to 18" x 24" paper. More material to explain this process can be found here: https://www.homedesignersoftware.com/search/?default_tab=support&q=printing DJP Link to comment Share on other sites More sharing options...
