Thab0425 Posted February 26, 2019 Share Posted February 26, 2019 Just another newbie with roof layout issues. See photos. I've read numerous help topics, videos, forum threads and I just can not get it right. Existing Roof. I'm assuming that little drop down over the garage is the culprit. Because when I sampled a L-shaped plan with out the drop down roof, i was easily able to create the gable ends and have the ridge-lines all meet. Addition floor plan Addition Roof. Link to comment Share on other sites More sharing options...
Thab0425 Posted February 26, 2019 Author Share Posted February 26, 2019 Thought i had turned it on, but i also tagged the software too. Thanks Link to comment Share on other sites More sharing options...
Thab0425 Posted February 26, 2019 Author Share Posted February 26, 2019 Sorry, thought the pictures explained it. I want the original roof line, with a third gable end as pictured, but with out all that mumbled mess at the top. Link to comment Share on other sites More sharing options...
Thab0425 Posted February 26, 2019 Author Share Posted February 26, 2019 2 minutes ago, solver said: And post the plan file. Done 1st_floor_Tara's_Idea.plan Link to comment Share on other sites More sharing options...
solver Posted February 26, 2019 Share Posted February 26, 2019 You want to clean up the area I've circled? Try breaking the wall at the red line. Set the back part to Hip. You should get a roof that follows the blue line. I'd place the break where the new wall joins the old. Link to comment Share on other sites More sharing options...
Thab0425 Posted February 26, 2019 Author Share Posted February 26, 2019 27 minutes ago, solver said: You want to clean up the area I've circled? Try breaking the wall at the red line. Set the back part to Hip. You should get a roof that follows the blue line. I'd place the break where the new wall joins the old. Yes sir, that's the area. I did as you said and I'm on the right track. It appears I now need to look into something else. I might have inadvertently inputted the wrong info into roof pitch somewhere. Link to comment Share on other sites More sharing options...
solver Posted February 26, 2019 Share Posted February 26, 2019 Made the pitch on the 2 new walls 4 instead of 5. 1 Link to comment Share on other sites More sharing options...
Thab0425 Posted February 26, 2019 Author Share Posted February 26, 2019 16 minutes ago, solver said: Made the pitch on the 2 new walls 4 instead of 5. You are the man!!! Thank you so much. perfect!! It seems you are the main provider of solutions on here, thank you for that. I'm sure we will meet again good sir. Thanks for the signature tips too. Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 26, 2019 Share Posted February 26, 2019 I thought you said that you wanted the roof ridges to align. Link to comment Share on other sites More sharing options...
Thab0425 Posted February 26, 2019 Author Share Posted February 26, 2019 I stated I wanted to keep the original roof line. I didn't want to modify the front half of the garage roof, as that would be a huge hit to the budget. But thank you for taking the time to do that. Link to comment Share on other sites More sharing options...
