Sylynn 0 Posted November 10, 2018 Hello, I am trying to manually change the riser height of a staircase, however that option seems to be greyed out. I've looked in the help section as well as searched the forums here, and both have indicated I need to uncheck "automatic heights". The problem is, I don't seem to have this option. Thanks in advance Share this post Link to post Share on other sites
DavidJPotter 202 Posted November 10, 2018 In order to obtain full manual control over stair objects, you would have to upgrade to Home Designer Pro or Chief Architect Interiors or Chief Architect Premier. I am sorry but that is the Truth of the matter. Architectural costs what it costs and does what it does. All you can do with Architectural is to vary and or lock the "Tread Depth" and then add or subtract treads With Pro, Chief Interior and Chief Premier you can manually set the bottom and top height as well as lock "Tread Depth", add and subtract treads manually, it does make a big difference with Stairs. DJP Share this post Link to post Share on other sites
Sylynn 0 Posted November 10, 2018 That's a shame. I get that each of the less expensive titles will have their limits, but it's quite annoying for it to come with a help file that doesn't indicate those limits, but rather tells you to do something you can't. Ah well... Thanks for the response! Share this post Link to post Share on other sites
solver 629 Posted November 10, 2018 34 minutes ago, Sylynn said: but it's quite annoying for it to come with a help file that doesn't indicate those limits, but rather tells you to do something you can't. Please take a minute or two and send this into support. The program is designed poorly too. Showing a value in a text box implies that it may be altered. * And thanks for filling out your signature! Share this post Link to post Share on other sites
Jo_Ann 174 Posted November 10, 2018 However, you will find that if you compromise just a little bit, you can come really close to what you want. Share this post Link to post Share on other sites
Sylynn 0 Posted November 12, 2018 On 11/10/2018 at 11:35 AM, Jo_Ann said: However, you will find that if you compromise just a little bit, you can come really close to what you want. How did you manage this? No matter what I do, I can't get the riser height to change Share this post Link to post Share on other sites
Jo_Ann 174 Posted November 12, 2018 ????? Open the stair dialog box and set the numbers as shown. Share this post Link to post Share on other sites
