carpenterjon Posted July 29, 2018 Share Posted July 29, 2018 I'm sure it's something stupid I'm doing, but in my floor plan view, the roof framing will not go away. It makes it impossible to click in the rooms or add or edit interior walls. How do I get rid of this? Thanks- Jon WilliamsJudd.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 30, 2018 Share Posted July 30, 2018 Number one: What software are you using: Version and Title name (Essentials, Interiors, Architectural, or Pro?) Number two: what is the pitch of the roofs of your actual house (not the virtual one in the plan file) Number three: do you have any photos of the existing house or a postal address so others can look at the actual house to be sure what it looks like? Number four: what framing, where, please? Framing like all visible objects in this software are on alphabetically named layers in "Display Options" and so can be turned on or off at will. DJP Link to comment Share on other sites More sharing options...
solver Posted July 30, 2018 Share Posted July 30, 2018 Edit>Delete Objects Or turn off the display of framing as David suggested. Link to comment Share on other sites More sharing options...
carpenterjon Posted July 30, 2018 Author Share Posted July 30, 2018 Diplay Options did it. Thanks David. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 30, 2018 Share Posted July 30, 2018 Display Options just visually turns off framing and other objects, it does NOT delete it, Once roofs and the design are just right only then order framing to be built. The auto Framing just follows how you create the walls, ceilings and roof planes, so I always leave that till last. DJP Link to comment Share on other sites More sharing options...
