BiggadaChief Posted June 27, 2018 Share Posted June 27, 2018 I need a roof over these two sections, that matches the real house. Suggestions? There is actually a deck between the two buildings, but there is also a "finished ceiling", which makes it weird... Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 27, 2018 Share Posted June 27, 2018 In Suite, your only control over roof baseline heights is the "ceiling height" setting in "Room Specification Dialogs - Structure Tab". Where roofs go and how they are configured are by way of pre-settings that YOU do in Wall Specification Dialogs per wall. This is explained generally in your "Build Roof Dialog - Roof styles Tab" per roof type. In order to obtain the exact result you want, all settings must be set properly before building the roof system. DJP Link to comment Share on other sites More sharing options...
Jo_Ann Posted June 27, 2018 Share Posted June 27, 2018 I think that your combo pic of the project and the real house is tell-tale revealing. Look at the eave height of the garage compared to the eave height of the adjacent house roof. Link to comment Share on other sites More sharing options...
