Select several objects
Chen12
That doesn't work for me. I open the floor plan, hold down "alt" and click on different walls but only one wall stays selected.
The same with rails (rail 1, rail 2, rail 3...) Only one stays selected.
What do I do wrong?
I still have the Home Designer Architectural 2016 version. Soon I plan to update.
The version is the reason?
Hold Control, not Alt if on a PC. Command if on a Mac.
You can also shift select items. This works for many object types, walls, cabinets etc.
To select all upper cabinets, first click the upper cabinet tool. Now holding shift, marquee around the uppers you want to select.
I checked my trial of Architectural and you can select multiple objects, but can only open a single selected object.
Another ridiculous limitation of the software.
FYI, Pro does not have this issue.
Sorry -- I did not read your initial post about selecting and opening, just noticed the reply by Rookie65.
