Cannot download bonus libraries
GoCreations
Another built-in method to finish installing downloaded library files is to be found under the "Library" menu, the command is called "Import LIbrary" when left-clicked upon a browse window dialog opens, that you use to navigate to your "Downloads" folder (where it actually is depends upon what browser you are using), select your intended calib or calibz file and then it will install provided it is intended for use in Architectural (some library files are just for Home Designer Pro,but you have to look and download the ones that are programmed just for Architectural).
