HandyRan Posted May 4, 2018 Share Posted May 4, 2018 Hello team, I recently upgraded to Home Designer Pro 2019. That being said I'm I process of designing a Pole Barn structure for a customer and I need to add Purlins to the trusses for roof structure as required by local building code. Because Pole Barns can have a 4' span on Truss installs you are typically required to add a horizontal 2 x 4 called a Purlin. I've attached a picture of the local requirements and also my Cross Section where I need to add them. I've tried adjusting roof blocking and roof beam but don't seem to be able to make one of those work. I will admit I'm a new user, but it would seem that one of these two should be able to make work. Link to comment Share on other sites More sharing options...
solver Posted May 4, 2018 Share Posted May 4, 2018 The program lacks a defined way of adding these. It's been requested many times. The simple solution is to create a detail like is shown in your first image. You can add thickness to your roof planes so they show in the correct spot. Draw the purlins with CAD lines. Link to comment Share on other sites More sharing options...
Jo_Ann Posted May 4, 2018 Share Posted May 4, 2018 This probably won't help with the 2d cross section, but it might help with the 3d presentation. Link to comment Share on other sites More sharing options...
HandyRan Posted May 4, 2018 Author Share Posted May 4, 2018 Thanks Jo Ann, really need it for 2d but will keep this in mind for later is needed. Link to comment Share on other sites More sharing options...
Pro2023UserMatt Posted October 20, 2022 Share Posted October 20, 2022 On 5/4/2018 at 10:46 AM, solver said: The program lacks a defined way of adding these. It's been requested many times. The simple solution is to create a detail like is shown in your first image. You can add thickness to your roof planes so they show in the correct spot. Draw the purlins with CAD lines. Has this been changed since OP? Link to comment Share on other sites More sharing options...
