llfalcon Posted February 7, 2018 Share Posted February 7, 2018 I searched the forums and couldn't find anything, although I'm probably using the wrong keywords. I have been able to create a recessed shower shelf like that in the attached image by using a window and changing the materials. It looks fine from the bathroom, but there's the same window showing on the wall of the adjacent room. Is there a better way to do this? Thanks! Link to comment Share on other sites More sharing options...
solver Posted February 7, 2018 Share Posted February 7, 2018 That's typically called a niche. You may have something in the library, or in one of the bonus catalogs available online. Use a Pass Through if Architectural has it (under windows). What are you seeing on the back side? You should have all parts of the window off so it's just a hole in the wall. You should be able to cover the hole with a soffit so from the back it looks like part of the wall. Link to comment Share on other sites More sharing options...
llfalcon Posted February 7, 2018 Author Share Posted February 7, 2018 I do have all parts of the window off, and it looks just like I want it to, from both sides of the wall. That's great for the bathroom, but not from the adjacent room. Pass-thru works the same. I was just hoping to avoid using a soffit if a more elegant solution were available. Many thanks. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 7, 2018 Share Posted February 7, 2018 2 hours ago, llfalcon said: I was just hoping to avoid using a soffit if a more elegant solution were available. That feature exists in Chief Premier X9 and X10 (Niche tool), as well as Home Designer Pro 2018 and Architectural 2018 but not what you currently have. DJP Link to comment Share on other sites More sharing options...
