Change Dormer material on walls
SAILOR139
The portion of the dormer exterior wall which is under the roof does not change to an interior wall; hence the material shows as siding instead of drywall.  How can this be rectified?  I an aware that a soffit or shape can be overlaid over the siding and painted.  Is there a correct solution?
