Where are 3D Symbols saved after being imported?
HandbuiltSpaces
When you import such symbol files part of the import process involves you choosing to "Add to Library" as part of that process. If you did not do this, then it was not done. if the symbols are part of a plan file you created you can, after the fact add such symbols to your library browser using the "Edit Toolbar" command "Add to Library".
