Acropolis Posted October 28, 2017 Share Posted October 28, 2017 Somehow, not clear where, therefore looking for help, the garage is submerges to floor below, somehow the default room above is 25, where are these defaults coming from, plan attached garage down under.plan Link to comment Share on other sites More sharing options...
Jo_Ann Posted October 28, 2017 Share Posted October 28, 2017 Ceiling (B) put a check mark in the default box. Floor (C) put a check mark in the default box. Link to comment Share on other sites More sharing options...
Acropolis Posted October 28, 2017 Author Share Posted October 28, 2017 Jo Ann thank you, that half fixes it, the roof becomes separated, and still cannot check monolithic slab foundation. If you check the slab definition is messes it all up. Link to comment Share on other sites More sharing options...
Jo_Ann Posted October 28, 2017 Share Posted October 28, 2017 Try setting the garage as unspecified, then check the those boxes and the monolithic slab box. The roof joining the garage is not correctly set, but I don't see it 'separating'. Link to comment Share on other sites More sharing options...
Acropolis Posted October 28, 2017 Author Share Posted October 28, 2017 none of that is working and defies logic since I've made plenty of these with garage, there is something in the code hidden, at least not obvious that is corrupting the result. I've compared a good one to a bad one and there is something behind the code that I cant see, If I set it up just like others I posted there should not be an issue - but the issue gets worse. so I'm trashing this file, its a waste of time, worse is the roof would not join the rest of the roof imes regardless of what I tried. Again there is something buried deep in the code screwing this up. Link to comment Share on other sites More sharing options...
LawB10 Posted October 29, 2017 Share Posted October 29, 2017 Why do you have all of your exterior walls checked as foundation?, your telling the software the first floor is the foundation. Uncheck foundation for all your exterior walls make the default setting for the foundation to monolithic slab, then do as Jo_Ann suggested. At the Laundry room, use the break wall tool for the top and bottom walls and make those walls interior and gable the bottom wall. Link to comment Share on other sites More sharing options...
Acropolis Posted October 30, 2017 Author Share Posted October 30, 2017 Went back to an old design and started from there - that one has "floor supplier by room below - assuming that means sub-structure like a basement or in this case a footing. And also monolithic is checked. That one worked, did not have the issue with building the roof which is hit or miss at best. Now I am missing a rafter - searched, but its not clear you can add one simple rafter in the place you want? its the same file, the main entrance peaked opening, at the junction to the main roof as it is open to below, and gable it wont put that rafter. copy paste doesn't work missing rafter gimped.xcf Link to comment Share on other sites More sharing options...
