Acropolis Posted August 13, 2017 Share Posted August 13, 2017 On many a plan, started over a year ago with HD17, Adobe Roof Tile was the choice. While I've been using HD18, I started a plan, and that Library material - Adobe Roof Tile is not there as a barrel type roof material, and in a dusty rose color as well, it points so an ugly color siding. Any ideas where it went? As a roof, its link isn't like fixtures or doors for example where you can copy over to the new plan, in this case its not been possible to copy it over to the new plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 13, 2017 Share Posted August 13, 2017 Between differing versions, material names and naming conventions can and do change. All Materials still exist in a particular Library Browser and so can be reassigned in a new unit of time as required. On 8/13/2017 at 12:30 AM, Acropolis said: Any ideas where it went? Expand It didn't "GO" anywhere but its internal programming location may have changed making it seem to "go", just look and figure it out and reassign your materials in Default Settings - Materials and in other pertinent dialogs as necessary. Just keep in mind that you are dealing with a Computer and Computer software where exact definitions of location on a Hard Drive and naming conventions are the "LAW". DJP Link to comment Share on other sites More sharing options...
Jo_Ann Posted August 13, 2017 Share Posted August 13, 2017 Open the material in the older plan, and look at it's color numbers in the material definition dialog. Write down those numbers. Then follow this kb article, and add the color numbers to the new material. https://www.homedesignersoftware.com/support/article/KB-00924/customizing-a-material.html Link to comment Share on other sites More sharing options...
Acropolis Posted August 14, 2017 Author Share Posted August 14, 2017 well after 5 hours of looking at ever possible setting - it isn't there, never was in the user materials group, where most custom stuff was saved. It may have been pulled a long time ago from one of the template plans that came with the s/w, checking to see if its there next. I had it set as the default roof tile - the wall materials are all there, but the roof did not come over to the new plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 14, 2017 Share Posted August 14, 2017 If you can still find it in your earlier version "HD2017" you said, then export that material from it to your desktop and then import into your HD2018 and then you will have it, try that then. You "right-click" on the Adobe Roofing material, and select export material as a .calibz file and then import that file into 2018, try that please. DJP Link to comment Share on other sites More sharing options...
Acropolis Posted August 15, 2017 Author Share Posted August 15, 2017 That was it, it is in the 2017 barrel tile profile, but not the 2018, little attention paid to reality, this is a color people use, not the horrific colors shown in 2018 version, not only are they not real, no one makes them or uses them. Now a right click isn't working......I had to export the entire barrel tile section and bingo - its all there in 2018 now. Thank you David. Link to comment Share on other sites More sharing options...
