crosscutter55 Posted June 24, 2017 Share Posted June 24, 2017 Is there a way , to make the dimension # be horizontal while the dimension line is vertical ? And if so how would I do it ? Is it in a settings ?? Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 24, 2017 Share Posted June 24, 2017 Take a look in "Default Settings - Dimensions" dialog. DJP Link to comment Share on other sites More sharing options...
crosscutter55 Posted June 24, 2017 Author Share Posted June 24, 2017 Looked in default settings only see that it can be placed above , below or centerd on dimension line Any other thought ?? I find it hard to bliieve this cant be done Link to comment Share on other sites More sharing options...
barthmv Posted June 24, 2017 Share Posted June 24, 2017 I believe you are correct in saying that dimension text can only be centered, above, or below the lines. Being able to rotate the text 90 degrees to the dimension line is pretty basic in most cad programs. HD pro seems to be limited to a number of things associated with dimensions. Another example of it's limitation is the ability to draw walls using ID room dimensions only. One has to use several methods to do this. Link to comment Share on other sites More sharing options...
crosscutter55 Posted June 24, 2017 Author Share Posted June 24, 2017 The only way i got around it , was to make a dimension line & use text to put the number in Link to comment Share on other sites More sharing options...
