CapeFront porch with shed roof
WindfallAdam
I do not see why you could not draw a Porch creating a Room Specification Dialog, set up the outer wall and side walls as per the "Roof Styles Tab" of the "Build Roof Dialog", make sure the porch room dialog has "Ceiling and Roof over this Room" checked and then auto-generate a shed roof over that defined porch or as Eric suggested just manually draw a shed roof. Either way you really need a porch area defined over which to create a shed roof.
