Walls turn black when I insert a window
Cloud8
ehh....  When I insert a window into a wall the wall turns black.
Just testing some stuff before I get too far.  The wall is just a default exterior wall.
I've used this company's software before, and am using the new version.  Architectural 2018.
Graphic card problem?
Thank you for your response Solver.
I updated my signature with the Chief Architect info.  It's Home Designer Architectural 2018.
I'm on a Win 10 box.
I attached the 'plan' that I am testing.  Just drew a wall and put a window in it.  The wall then turns black.
Thanks again.
Test1.plan
Good suggestion.  I am working on a desktop so I could upgrade it, but it is a few years old.  Wasn't planning on replacing it for at least 2 more years. And all I want the software for is a simple project.
Thanks
On ‎5‎/‎7‎/‎2017 at 3:01 PM, swarren said:
If you cannot replace your card (say you have a notebook), maybe you can get CA to back rev you to 17.  I used HD 17 Pro just fine with GL 3.1 on a 5 year old HP notebook.
This did the trick.  Thanks all.
Cloud8
