4ndrew Posted March 25, 2017 Share Posted March 25, 2017 Hi everyone, Back to experimenting with HD for some home projects... I am planning on doing some interior work as well as landscaping / hardscaping design and think this package might work. I'm jumping around a bit, but trying to figure out how to model this roof, specifically, how to make part of the house where the roof is longer (sloping surface is closer to ground on one side of the roof than the other) - also how to create the join above the front door where it interesects two other roofs if possible. I'm not changing anything with the roof, but would really like to learn how to model this... I've attached a few Google Earth snaps of the house and also a Street view of the front. Any help really appreciated! thanks Andrew Link to comment Share on other sites More sharing options...
LawB10 Posted March 25, 2017 Share Posted March 25, 2017 Without knowing what HD software you are using and just from the pics alone. I'd say build a 2nd floor and gable the roofs, create an entry on the 1st floor and gable the side walls, the room above the entry is not gabled. Link to comment Share on other sites More sharing options...
4ndrew Posted March 25, 2017 Author Share Posted March 25, 2017 Hi all, I'm running the 2018 Pro demo. That's why my sig was empty - just updated. thanks, Andrew Link to comment Share on other sites More sharing options...
4ndrew Posted March 25, 2017 Author Share Posted March 25, 2017 19 minutes ago, LawB10 said: Without knowing what HD software you are using and just from the pics alone. I'd say build a 2nd floor and gable the roofs, create an entry on the 1st floor and gable the side walls, the room above the entry is not gabled. Thanks - but I'm not sure how to make the roof sides different lengths. (See attached) (edit) Or, to look at it another way, how to make the walls different heights Link to comment Share on other sites More sharing options...
4ndrew Posted March 25, 2017 Author Share Posted March 25, 2017 Thanks Eric - I didn't know that's what it was called. I'll take a look around. Link to comment Share on other sites More sharing options...
4ndrew Posted March 25, 2017 Author Share Posted March 25, 2017 Works great! Now, to figure out the joins and porch roofs... thanks again Andrew Link to comment Share on other sites More sharing options...
