Steeple
ChrisF
I got it thanks for the help.
The soffit command worked.  But it was not as easy as I had hopped.  I there a good video I could watch to better understand how to use them in these unique situations?
Thanks again.
Soffits are a real general purpose shape. What part of using them did you find "not as easy as I had hopped."?
I don't know of any videos, but will try to give you some general pointers.
I guess I will use the cross as an example.
I built it in three pieces.
1) The main vertical member
2) The left side
3) The right side.
Now the biggest  issue was the alignment.  I had to move around trying to place 2 & 3 where I wanted them.
Is there a way to snap the faces together?
You can create Architectural Blocks, which combine multiple parts into one.
In this image is a cross made from 2 soffits, one for the vertical, one for the horizontal. I selected them both, and made them into an Architectural Block. I can now move these as one.
I would have assembled the steeple on the ground from various parts, blocked them together, moved the assembly directly under its location, then used Transform/Replicate to raise it into position.
1 hour ago, Jo_Ann said:
???  Why on earth would you use 3 pieces when only 2 pieces (horizontal & vertical) are needed???
Sounds like you need to do some studying.
Jo_Ann,  Why?  What is the point of that post?
For your information the very large 3D modeling program I use for my day job.  Does not allow me to cross two members like that.  SO my mind defaulted to that fact and I would need to built them as separate sides.  (Sense 3 pieces is how the cross would be built in real life)  This was my first attempt at using soffits.
I am trying to learn Home Designer on my own.  With help for this forum as I need it. Sorry, I am not fully up to date on all of its abilities.
Thank you for your earlier post it helped me in understanding how you were able to build it.
