AirstreamJake Posted February 9, 2017 Share Posted February 9, 2017 I have the home design 'pro' version, but I am a definite amateur when it comes to this software. I am trying to align two doors on opposite walls of a screened room. One door enters into the screened room from outside the building. The other door is on the wall which separates the screened room from the interior of the house itself. I want the two doors to be aligned so that the hinged side is equidistant from the framing layer of the end of the porch. Link to comment Share on other sites More sharing options...
AirstreamJake Posted February 9, 2017 Author Share Posted February 9, 2017 I have HD Pro 2017 Version. My specific question is: How do I align two doors that are on opposite walls so that each door is the same distance from a common wall? Link to comment Share on other sites More sharing options...
solver Posted February 9, 2017 Share Posted February 9, 2017 Select the door, adjust using dimensions. Link to comment Share on other sites More sharing options...
Elovia Posted February 10, 2017 Share Posted February 10, 2017 If you have one door already in place, and the two doors are the same size, you can use ctrl-g to center the unfixed door to the fixed one. Take a look in the reference manual about centering objects relative to other objects. Good luck. Link to comment Share on other sites More sharing options...
katalyst777 Posted February 14, 2017 Share Posted February 14, 2017 There's a Center Object edit tool that will probably work for what you want as well. Link to comment Share on other sites More sharing options...
