mmdesignbuild Posted January 6, 2017 Share Posted January 6, 2017 This project is an addition - the new structure ties in to the house adjacent to an area that has a vaulted ceiling (see attached). Since I want to leave the existing vaulted ceiling as is, I plan to "piggy back" the new roof over the old. The problem I am having is on the interior views. The existing vaulted ceiling is following the new roof line where they meet (see attached). How can I maintain the original roof vault when I add the new roof above? Thanks!! Link to comment Share on other sites More sharing options...
solver Posted January 6, 2017 Share Posted January 6, 2017 You might post your plan file. Make sure it's not open in the program. Look in your library for Inverted Wedge. If you have it, it could be used to fill in the space. Link to comment Share on other sites More sharing options...
mmdesignbuild Posted January 6, 2017 Author Share Posted January 6, 2017 thanks for the reply unfortunately not going to be able to pull it off with an inverted wedge - Link to comment Share on other sites More sharing options...
Jo_Ann Posted January 6, 2017 Share Posted January 6, 2017 I think that your only solution will be to build a sloped ceiling plane in sketchup, and import it into the program. Link to comment Share on other sites More sharing options...
mmdesignbuild Posted January 6, 2017 Author Share Posted January 6, 2017 If that is my only solution I think I'm sunk (old dog new tricks.........) thank you for the response Link to comment Share on other sites More sharing options...
TomGriff Posted January 7, 2017 Share Posted January 7, 2017 Try placing a room divider where you want the original vaulted ceiling to extend and check the "ceiling over this room" box in the new addition. Tom Link to comment Share on other sites More sharing options...
