Limit width of cross section elevation
rfcomm2k
Go to solution Solved by DavidJPotter,
I wish to see a wall elevation of kitchen cabinets. However, if I select "Wall Elevation" from the menu, I cannot add dimensions to it.
If I select "Cross Section/Elevation" from the menu, I can add dimensions, but the section line carries with it the entire structure. I wish to see only the part of the elevation that relates to the kitchen cabinets.
I could probably print the file to a PDF and then use an external editor to blank out the parts I do not want to see, but I was hoping this can be done within HD Pro.
