ChiefuserLarkin Posted September 1, 2016 Share Posted September 1, 2016 First time it's done this and I did a Saveas to existing plan that had no issues with. Checked all the rooms. Link to comment Share on other sites More sharing options...
ChiefuserLarkin Posted September 1, 2016 Author Share Posted September 1, 2016 The floor joists. Link to comment Share on other sites More sharing options...
ChiefuserLarkin Posted September 1, 2016 Author Share Posted September 1, 2016 When I built the framing for the floor it only built the floor joists as shown on the snip. First time ever it's done this so just trying to figure out what's going on. I don't need them for the documents, just want to know the issue. Plan attached. Using HD17 Thanks Jason 1830 Ranch.planFetching info... Link to comment Share on other sites More sharing options...
DCortes Posted September 1, 2016 Share Posted September 1, 2016 I do not get the same result as you do. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 1, 2016 Share Posted September 1, 2016 You should carefully read the Reference Manual sections that address framing and the framing dialog. I think that is what you need to do and then practice what you learned. DJP Link to comment Share on other sites More sharing options...
Solution ChiefuserLarkin Posted September 20, 2016 Author Solution Share Posted September 20, 2016 Some of the room dbx's didn't have the structure checked. Problem solved. Link to comment Share on other sites More sharing options...
