Sign in to follow this
ChiefuserLarkin
Floor framing issue
Is this a game?
Specifically -- what is wrong?
You will also get far better responses if you post the plan file.
Also please fill out your signature -- see below.
It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click My Settings, then Signature on the left.
Resources for self help:
When I built the framing for the floor it only built the floor joists as shown on the snip. First time ever it's done this so just trying to figure out what's going on.  I don't need them for the documents, just want to know the issue.  Plan attached.  Using HD17
Thanks
Jason
1830 Ranch.plan
You should carefully read the Reference Manual sections that address framing and the framing dialog. I think that is what you need to do and then practice what you learned.
