LiteMari Posted June 18, 2016 Share Posted June 18, 2016 I am designing a modern home in Home Designer Pro and am considering using James Hardie fiber cement panels (4' x 8' sheets) that would use trim such as Fry Reglet or Easy Trim at the 1/2" reveal where panels "meet". What would be your suggestion for giving an approximation to what this might look like on the house design? I might leave the aluminum reveal as is, or might paint to match the panel color, but initially would want to model the aluminum reveal look.I want to get a sense of the exterior appearance but also want to explore variations of where the vertical and horizontal reveals would be in relationship to the vertical and horizontal exterior line of window and door cladding so as to balance appearance with minimizing the number of cuts as well as wasted material. I have started with making the exterior material stucco as this is in ballpark of my color choice. Thanks for any suggestions. Link to comment Share on other sites More sharing options...
solver Posted June 18, 2016 Share Posted June 18, 2016 Have you searched the forum? I remember discussing this sometime in the last year or two. Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted June 18, 2016 Solution Share Posted June 18, 2016 What Eric means is that how to create custom materials has been discussed here before. If you know how to create custom materails, you can do whatever you like with them within their barriers. Also read some these help articles: https://www.homedesignersoftware.com/search/?q=custom+material DJP Link to comment Share on other sites More sharing options...
LiteMari Posted June 18, 2016 Author Share Posted June 18, 2016 Thank you both. I will look at the articles and should be able to create a custom material. Link to comment Share on other sites More sharing options...
solver Posted June 19, 2016 Share Posted June 19, 2016 We discussed this type of siding and how to model it. Numerous ways to do the panels. Not sure a custom material is needed here. Link to comment Share on other sites More sharing options...
