Kentski Posted June 1, 2016 Share Posted June 1, 2016 Good day, I'm working on an industrial project and was wondering if anyone new how to change balusters to horizontal rails on a staircase. The decking uses a 3 rail (rounded) railing and I need the stairs to match. Any help would be greatly appreciated as the standard upright balusters don't really match. Cheers Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 1, 2016 Share Posted June 1, 2016 To answer your question with certainty I would have to know what version and title you have. In Pro or Chief Premier you turn off the stair's railings and then draw a railing wall on the outside of the stairs using a rail wall of the type you desire marked "Follow Stairs" but this method will probably not work in Essentials, Suite, Interiors or Archtectural. DJP Link to comment Share on other sites More sharing options...
Solution Kentski Posted June 1, 2016 Author Solution Share Posted June 1, 2016 Wow... that easy, thank you very much. I have Chief Premier and was use to Datacad. Your help was extremely time saving, much appreciated and thank you for the prompt reply. Have a splendid day knowing you helped out someone quite desperate. Cheers. Link to comment Share on other sites More sharing options...
solver Posted June 2, 2016 Share Posted June 2, 2016 I see you have Premier. You are on the Home Designer forum. You want ChiefTalk. Link to comment Share on other sites More sharing options...
