Sign in to follow this
English
Window & Door Label Format
My contractor wants the door and window label to be in inches only.  The default format is feet and inches.  For example for a 32" wide door 80" high the default is  28/68. I need it be 32/80 and I can't seem to find where to change that.
Thanks
Alan
Tell your contractor to learn to use industry standard notation, or to give you the cash to upgrade to Premier.
You can also use your own label, changing each window and door manually.
Eric you took the words right out of my mouth, that's exactly long time ago.  Even provided him a cheat sheet at that time so he could learn, but that's when I was using REVIT.
I thought that the default was industry standard but he's paying the bill.  I just have to change each one manually.
Alan
