SAILOR139 Posted February 15, 2016 Share Posted February 15, 2016 How does one output the maximum quality (high resolution) image in Suite? Does it matter which format to output the image? Link to comment Share on other sites More sharing options...
katalyst777 Posted February 15, 2016 Share Posted February 15, 2016 If you are talking about 3D, you might want to make it as large on screen as you can, then use Final View with Shadows before you export.Pro has more options on exporting images for the size/resolution, but from looking at the Comparison Matrix, I don't think Suite has that feature. 2 Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 16, 2016 Share Posted February 16, 2016 Image quality and resolution are determined by the size of your monitor and quality of your video card. Other that those two factors the limiter overall is the computer language used by all Home Designer titles including Home Designer Pro is called "Open Graphic Language" ( Open GL )which is the way a PC can translate graphic information and make it visible to the eye. This is also true of Chief Architect Premier except that Premier also has a Ray Tracing application ( a separate rendering image application) that can increase the resolution and size of an image, The larger the image output the longer it takes to create. The file format is something you can experiment with (.jpg, .bmp, .png, .tiff and .gif) , I prefer .jpg for several reasons and have not observed a marked difference between image file formats worth mentioning. DJP Link to comment Share on other sites More sharing options...
jeffreybianchi Posted February 24, 2016 Share Posted February 24, 2016 For what it's worth...I'll investigate my graphics card but I have had good results with this method (albeit multiple steps!) 1. Make the rendering as large as you can on your screen. 2. Do "print screen" and copy to Microsoft PAINT 3. Crop the image and save into a new Chief Architect PLAN file. 4. Send plan file to layout, then follow the steps to save as a PDF. I get ten times better resolution for presentation drawings when using this method. If someone has a better way to build the mousetrap, I'm all ears! Link to comment Share on other sites More sharing options...
