Sloped Driveway
English
I'm trying to create a sloped driveway to my basement garage.  I tried using a slab but it cannot be set at an angle (that I could see).  I tried a soffit and got it where it looked okay on the flat (correct width and thickness).  I had the elevation at -143" and checked the Sloped Soffit box and the ending elevation changed to -138" but when I tried to change that to -16" it defaulted to 1/16" and wouldn't accept any other number.
Am I using the wrong item to create a sloped driveway?
Thanks
Alan
Wow thanks Kat that looks great.  As I said this is the first time using terrain and I'm still learning.  BTW I went onto the HD website and read the article - Modeling Terrain for a Walkout Basement (http://www.homedesignersoftware.com/support/article/KB-00718/modeling-a-sloping-terrain-for-a-walk-out-basement.html) and I did exactly as described but when I click on Build Terrain nothing happens.  That article says that the software will put intermediate contour lines between the ones I added but it doesn't.
Any ideas?
Thanks
Alan
You had most of the terrain layers turned off in the version of the plan I pulled from the other thread, however I don't recall whether Terrain, Primary Contours was one of them that I had to enable, but that would be my guess for as to why you didn't see them after using Build Terrain.
The plan I attached earlier has a couple of other modifications I made after taking the screenshot, like doing a manual terrain hole so that there wouldn't be the blank space around the back of the building that was auto cut out by the first floor.
Okay thanks for that -- I always wondered how to fix that issue.  I am working on the top of the driveway -- got the little issues fixed and am now adding the walkway.
Alan
Kat
I found out what I was doing wrong (or in this case not doing).  The tutorial I referred to seems to be missing a step and that is setting the elevations of the terrain lines that you draw.  I know now it's obvious but it should have been included for us dummies.  :)
Thanks
Alan
