bdfulbright Posted January 7, 2016 Share Posted January 7, 2016 Using Home Designer Suite 2016 Have a garage with living space upstairs. Upstairs deck extends over the garage door below. I have two options, in order of preference: 1) Cantilever the deck so no support posts are required. The software is auto-generating posts. Based on tutorials, "pro" can eliminate these in "defaults/rooms/deck". This does not appear to be available in Suite. Anyone know? 2) Since the deck is supported on two sides with walls, I should be able to have the joists run parallel to the garage, thus removing the need for posts. Cannot see how to set joist direction. 3) Remove the post by beefing up the beam to have a greater span. Cannot find how to define structural spans. THANKS! Link to comment Share on other sites More sharing options...
solver Posted January 7, 2016 Share Posted January 7, 2016 Don't understand what you are modeling. How is the "deck is supported on two sides with walls"? You might consider using Balcony instead of Deck for the room type. Suite lacks the framing tools you need. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 7, 2016 Share Posted January 7, 2016 How much cantilever will be determined by the strength of the intended support members (best left to a Licensed Structural Engineer to calculate accurately). Otherwise, Eric has indicated a proper solution (naming the deck as a balcony), naming a space "deck" has automatic and in this case unwanted results. Name the space "Balcony" and have an Engineer review your plans so the proper structural strength can then be applied. DJP Link to comment Share on other sites More sharing options...
Solution bdfulbright Posted January 7, 2016 Author Solution Share Posted January 7, 2016 Thank you all -- Defining the room BALCONY does the trick! Link to comment Share on other sites More sharing options...
