Center Plot
MatE
Go to solution Solved by MatE,
"Print - Center Sheet" if you intend to print directly from a plan file view, though the usual way with Pro is to print from a .layout file where you can arrange and scale several views on a single page. There is additional choices to be made under "Print - Scale to fit and Drawing Sheet Set Up" that you should study up in the Reference Manual before using.
  • Solution
Thank you both, I haven't played with the layout yet, so that will be a good education to play with.  Some how (By Accident) The Sheet Boundrys shows up under the plan view, I might have selected as you mentioned accidently?  I Windowed all and "back" windowed just the page to deselect it.  then moved with the "grab box" "I think"???  Thanks Again
