jjbNana Posted October 15, 2015 Share Posted October 15, 2015 I have a skylight in each of the 2 bathrooms on my 2nd floor. When I place a skylight in the room, at the location on the ceiling where the shaft begins, but the shaft doesn't go straight up at a 90* angle from the ceiling. Rather, the shaft goes up at an angle to end meeting the roof at a 90* angle. I cannot seem to find a way to tilt the shaft to meet the pitch of the roof perpendicular. I'll measure and calculate the roof pitch this weekend. Thanks, in advance for your time, suggestions, and assistance. R/Joe Link to comment Share on other sites More sharing options...
DCortes Posted October 16, 2015 Share Posted October 16, 2015 Post the plan so we can look at it and see whats going on there. With all the knowledge here you will get the right answer. Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted October 16, 2015 Solution Share Posted October 16, 2015 I just checked in Suite, Architectural and Pro and they all have precisely the same dialog box and settings as to" Angle for Inside Hole Rim". That is the only setting I see that would vary the skylight shaft angle. You would have to upgrade to Chief Architect Premier to gain full control over the shape and angle of the skylight shaft. DJP 1 Link to comment Share on other sites More sharing options...
jjbNana Posted October 21, 2015 Author Share Posted October 21, 2015 Thanks, guys. Appreciate it. R/Joe Link to comment Share on other sites More sharing options...
DIYPete Posted September 23, 2024 Share Posted September 23, 2024 On 10/15/2015 at 9:28 AM, jjbNana said: I have a skylight in each of the 2 bathrooms on my 2nd floor. When I place a skylight in the room, at the location on the ceiling where the shaft begins, but the shaft doesn't go straight up at a 90* angle from the ceiling. Rather, the shaft goes up at an angle to end meeting the roof at a 90* angle. I cannot seem to find a way to tilt the shaft to meet the pitch of the roof perpendicular. I'll measure and calculate the roof pitch this weekend. Thanks, in advance for your time, suggestions, and assistance. R/Joe I have just the opposite problem. The shaft goes up at a right angle to the ceiling, but I want the shaft to go up at a 77° angle. I am using HD Pro 2025. Link to comment Share on other sites More sharing options...
