GWihbey Posted October 12, 2015 Share Posted October 12, 2015 Using the stair tool I've been unsuccessful getting the roof to cover stairs. I am using a slab/stem wall foundation with a "floating deck" for the porch. I looked at webinar that manipulated slab to make stairs in pool and felt that was helpful getting me close to a solution, but can't seem to find a resolution. Any help would be great. I am using 2016 pro edition. sketch bonus room1 with garage bump_auto_save_bak.plan Link to comment Share on other sites More sharing options...
LawB10 Posted October 12, 2015 Share Posted October 12, 2015 Did try adjusting you're eave overhang? Link to comment Share on other sites More sharing options...
LawB10 Posted October 13, 2015 Share Posted October 13, 2015 Create a bump out room, gable the side walls and then click on the front wall, click extend the slope downward. Make the walls invisable. Link to comment Share on other sites More sharing options...
solver Posted October 13, 2015 Share Posted October 13, 2015 ? Link to comment Share on other sites More sharing options...
GWihbey Posted October 15, 2015 Author Share Posted October 15, 2015 Thank you. Yes this scenario would be something I could work with and have struggled to accomplish...Would explain what I would need to do, to make the thumbnail you attached? Thanks again! Link to comment Share on other sites More sharing options...
solver Posted October 15, 2015 Share Posted October 15, 2015 I did, basically, what you did to form the bump out on the porch. Just turned off the floor by defining the room as Open Below. Draw in 3 Room Divider walls to enclose the steps. Make sure a room is created and you will get the roof. Link to comment Share on other sites More sharing options...
