Scottisimo Posted August 22, 2015 Share Posted August 22, 2015 Hi, I have just started learning HD Pro, and have run into a snag. The Users Guide told me to create an interior dimension, so I did, and got the 3' and 6'5 dimensions, whereas they got one dimension that was not broken into 2 parts. Now they want me to move the vertical wall so that the interior dimension is 9'7-3/4. I'm trying to move the wall using dimensions, just like I moved all the exterior walls into place, but it is not working. I can't move that wall using dimensions, or by dragging it. There are no drag handles on it. Can anyone help? Link to comment Share on other sites More sharing options...
Kbird1 Posted August 22, 2015 Share Posted August 22, 2015 I have no idea what you are attempting , but a page no# from the UG or some pics or something would probably help. if you are too close to another wall , the interior dim. may break either side of it ? it depends on how your dimensions are set up to Locate Objects in the Dimension defaults. Link to comment Share on other sites More sharing options...
Scottisimo Posted August 22, 2015 Author Share Posted August 22, 2015 I was trying to attach the file I was working on, but somehow it didn't upload. What is the correct procedure for doing that? Link to comment Share on other sites More sharing options...
Kbird1 Posted August 22, 2015 Share Posted August 22, 2015 You cant upload plan files if you have the plan open in HD , the plan must be closed , HD can still be open though.. See the 2nd link in my forum signature ...how to post plans and pics if needed. you also need to fill in your Profile Signature please..... see the 1st note in my sig for a how to as well below.... Link to comment Share on other sites More sharing options...
Scottisimo Posted August 22, 2015 Author Share Posted August 22, 2015 Hopefully I have now filled in my signature, posted a photo, and attached the plan file. Users Guide_auto_save_bak.plan Link to comment Share on other sites More sharing options...
solver Posted August 22, 2015 Share Posted August 22, 2015 By "vertical wall" I'm guessing you are referring to the wall to the right of the 6' 5" dimension. I can select that wall and drag it, or move it with the dimension. Why can't you move it with the dimension? -- what happens? Link to comment Share on other sites More sharing options...
solver Posted August 22, 2015 Share Posted August 22, 2015 And, if you create your interior dimension in the upper part of that space, you should get a single number, not the split dimension that results when you draw the dimension line closer to the lower part of that space. The software is being "smart". Just clicking on that wall will give you temporary dimensions which can be used to move the wall too. Link to comment Share on other sites More sharing options...
solver Posted August 22, 2015 Share Posted August 22, 2015 And, you can add and remove dimension locations from a dimension line. If you don't want it split into 2 parts -- remove one. Link to comment Share on other sites More sharing options...
solver Posted August 22, 2015 Share Posted August 22, 2015 I'd also suggest watching the Home Designer videos on YouTube before working on the tutorial. Many are specific to Home Designer, but the Chief Premier ones are worth watching as well eventually, as Pro is a subset of Premier. Also check out the Knowledge Base (before asking here please ) when you need help. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 22, 2015 Share Posted August 22, 2015 Hopefully I have now filled in my signature, posted a photo, and attached the plan file. Perfecto ...Mucho Gracias.... Think Eric has been busy while I was Gone but it looks like you just drew the dimension line too close to the Doorway (opening) , the default "reach" for dimensions in the Plan Defaults is 24" , if you can't move 2' away , reset the default to 12" and it will work as expected. see the pics Link to comment Share on other sites More sharing options...
Scottisimo Posted August 22, 2015 Author Share Posted August 22, 2015 By "vertical wall" I'm guessing you are referring to the wall to the right of the 6' 5" dimension. I can select that wall and drag it, or move it with the dimension. Why can't you move it with the dimension? -- what happens? If I click on the vertical wall on the right, and then click on the dimension, which is now 9'5, the dimension does not get highlighted, and I cannot change it. Link to comment Share on other sites More sharing options...
Scottisimo Posted August 22, 2015 Author Share Posted August 22, 2015 If I click on the vertical wall on the right, and then click on the dimension, which is now 9'5, the dimension does not get highlighted, and I cannot change it. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 22, 2015 Share Posted August 22, 2015 I am not sure what's going on cos if I click on that wall I get 4 different clickable dims, all which allow me to move or alter the wall, is your wall definitely selected ? Link to comment Share on other sites More sharing options...
solver Posted August 22, 2015 Share Posted August 22, 2015 Click on the wall, then click on the dimension you want to change. Watching some video will make things like this clear. Link to comment Share on other sites More sharing options...
Scottisimo Posted August 22, 2015 Author Share Posted August 22, 2015 I am not sure what's going on cos if I click on that wall I get 4 different clickable dims, all which allow me to move or alter the wall, is your wall definitely selected ? Capture2.JPG Something's wrong with my plan. I just tried clicking on every wall in the plan. When selected, they should turn gray, and then when you hover the cursor over a dimension, it should turn highlighted in blue. None of that is happening. Link to comment Share on other sites More sharing options...
solver Posted August 22, 2015 Share Posted August 22, 2015 Try drawing a new plan. Hovering over a dimension will change the pointer if it's a dimension associated with something you clicked on. I'm not sure about the dimension changing color -- it does not work that way here and we are using the same software. Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 22, 2015 Share Posted August 22, 2015 Please view this You Tube tutorial video I made about "Dimensions" and "Moving Object by dimension" https://www.youtube.com/watch?v=5smDg7bbtBs DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted August 22, 2015 Share Posted August 22, 2015 Don't assume the colours are what in the tutorial as the tut may have been made in another version or the person may have changed their default colours , eg my selection colour is Pink as I find it easier to see ( it's a Dan Baumann Tip from Chief Experts) and my selectable dims go light grey not blue ...at least they do in your plan ...see my pic above. I am using your plan , so I don't think it's that ...... mouse working okay in all other Apps ? Link to comment Share on other sites More sharing options...
Scottisimo Posted August 22, 2015 Author Share Posted August 22, 2015 I don't know if my posts are coming thru. They don't seem to be visible on this forum after I post them. Is there a delay? Anyway, I solved the problem. I wasn't clicking on the Select Objects tool before clicking on the wall that I wanted to move. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 22, 2015 Share Posted August 22, 2015 Not usually , normally you see it post immediately , but if you leave the reply window open too long and don't do anything it times out ....and sometimes kicks you back to the main forum. Yes , being in Select Mode helps ...I was right after all.... The easy way out of a selected mode is the Spacebar , which puts you back in Select Mode AFAIK , while the ESCape Key lets you cycle through previous selected modes , might want to check that in the Ref.Manual too. Link to comment Share on other sites More sharing options...
Scottisimo Posted August 23, 2015 Author Share Posted August 23, 2015 Not usually , normally you see it post immediately , but if you leave the reply window open too long and don't do anything it times out ....and sometimes kicks you back to the main forum. Yes , being in Select Mode helps ...I was right after all.... The easy way out of a selected mode is the Spacebar , which puts you back in Select Mode AFAIK , while the ESCape Key lets you cycle through previous selected modes , might want to check that in the Ref.Manual too. Kbird1, what does AFAIK stand for? Link to comment Share on other sites More sharing options...
Scottisimo Posted August 23, 2015 Author Share Posted August 23, 2015 Mick, what does AFAIK stand for? Link to comment Share on other sites More sharing options...
Scottisimo Posted August 23, 2015 Author Share Posted August 23, 2015 I notice that several of you fellows seem to offer a 3D drafting service. I have an upcoming project, which involves demoing an existing one story house down to the subfloor, leaving the subfloor and a few walls for tax purposes, and then building a 3700 SF 2 story house around the old subfloor. There's nothing particularly complicated about the house. Flat lot, colonial style, I already have the 2D plan minus the finish details (but the plans are hand drawn by a draftsman that does not use a computer). Anyone want to give me a rough quote for turning it into 3D and teaching me how to use the 3D plan? I may or may not actually do this, but am curious to know what it would cost. Link to comment Share on other sites More sharing options...
solver Posted August 23, 2015 Share Posted August 23, 2015 Google will answer your question about AFAIK. AFAIK = As Far As I Know If you have the plan on paper, you already have much of the work done. Draw it with Pro, and you get the 3D automatically. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 25, 2015 Share Posted August 25, 2015 DJP and I both help People out at times , David actually teaches HD/CA via GoToMeeting (GTM) Online on an hourly basis as well as doing Drawings for Clients, so if it's lessons you need , just find one of his Posts here, his Contact details are in his SIG. Mick. Link to comment Share on other sites More sharing options...
