ed612313 Posted July 12, 2015 Share Posted July 12, 2015 Hi guys, I have a flat roof and am wanting to show a roof top garden to these flat roof areas... Is it possible? Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 12, 2015 Share Posted July 12, 2015 Yes: DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted July 12, 2015 Share Posted July 12, 2015 these two articles should help with the flat roof , but I haven't tried putting a garden bed on a Roof as yet , though it should work I'd think. http://www.homedesignersoftware.com/support/article/KB-00120/ http://www.homedesignersoftware.com/support/article/KB-00877/ Link to comment Share on other sites More sharing options...
RobynKS Posted July 12, 2015 Share Posted July 12, 2015 Hi I just tried to do this I put a flat roof onto the end of my drawing In "Plan View" I went to plant chooser and selected herbs. I then tried to place the plants on the plan. When I looked with the camera the plants were on the ground. Naturally LOL this programs not silly.... In perspective view I selected the plants and changed their above ground height. You should group select the plants and make an Architectural Block and add to your library. When you hold the shift key and select the plants a small colored box will be on the bar in the bottom left corner of your screen. Once you have that block click on it and Open it. The open command is a small "Book" icon in the left hand bottom side of your screen. Then you can from that screen change the floor height of the plants. However someone else may have a better solution as I am still learning Pro Link to comment Share on other sites More sharing options...
katalyst777 Posted July 13, 2015 Share Posted July 13, 2015 If you create a room, instead of using a roof plane, the plants shouldn't need to have their height value adjusted. Link to comment Share on other sites More sharing options...
