RobynKS Posted July 11, 2015 Share Posted July 11, 2015 Hi all in photo one:- Is the way a quick floor and site plan looks in HD Pro. In photo 2 and 3:- This is the way our local Real Estate agents like to present a plan layout of existing properties for sale. My question are:- 1. I cannot workout how to colour the wall outlines in solid black. 2. How to colour the rooms. 3. I need to remove the grid lines for the screen shot once I have drawn the plan If I have not explained this is a manner you understand please let me know. Many Thanks in advance Robyn Link to comment Share on other sites More sharing options...
Kbird1 Posted July 11, 2015 Share Posted July 11, 2015 Don't have Pro to look at but think this should help..... 1. Walls ...use display options and turn on "main layer only" 2. Select the Room and use the Fill option ,set to solid choose colour and transparency wanted 3 the grid is just the reference display by the looks just toggle it on and off with the icon which is usually on the right hand sidebar. For quick realty stuff you might want to look at the Space Planning Option too, once rooms are placed ,your then convert it to walls as normal. M. Link to comment Share on other sites More sharing options...
RobynKS Posted July 12, 2015 Author Share Posted July 12, 2015 Mick Thank you was able to achieve all that you explained bar Changing the wall outlines to Black. Link to comment Share on other sites More sharing options...
solver Posted July 12, 2015 Share Posted July 12, 2015 . Link to comment Share on other sites More sharing options...
Kbird1 Posted July 12, 2015 Share Posted July 12, 2015 Eric has the Pic for you above,but you need to change the default HD Pro Wall Fill to Black if you want the walls to be black not the default Blue or Yellow. Link to comment Share on other sites More sharing options...
