Upper corner cabinet with diagonal face
NorseMN
I have Home Designed Pro 10.
I can't find any upper kitchen cabinets that have a diagonal door.
I've tried to convert existing styles, but the software refuses to cooperate.
The only style of upper corner cabinet avaialble has a square notch on its face, rather than a diagonal face.
Is there any hope for me?
Thanks
Reid
Aahhh! Thank you very much.
I've looked for that off and on for years.
But after checking the diagonal door option, I got a front door that's a convex hemisphere.
I recall mention of a parameter that's set +/- for concave/convex, but now I can't find that in the cabinet dialog.
Can you provide one more helpful suggestion?
Thanks,
Reid
for other readers....
it's doesn't show up unless you turn on Corner cabinets but the second box on the Right side controls the in and out , it usually defaults to 0" = straight.
from the manual
For corner cabinets, the Width and Depth fields become Right Side Width and Left Side Width. If a corner cabinet is assigned a diagonal door on the Front tab, the second Right Side Width field specifies the bow depth: a positive num­ber creates a bow and a negative number, an inside bow.
  • 11 months later...
