selectbuilder Posted May 12, 2015 Share Posted May 12, 2015 It seems to be answered in the Knowledge base but unfortunately its for a PC. Can anyone please help me with this? thank you Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 12, 2015 Share Posted May 12, 2015 Are you asking about changing the apparent material size of a tile material of something else please? DJP Link to comment Share on other sites More sharing options...
selectbuilder Posted May 13, 2015 Author Share Posted May 13, 2015 Yes David sorry about that. Trying to change what I'm assuming 12'x12' to 12' x24'. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 13, 2015 Share Posted May 13, 2015 It seems to be answered in the Knowledge base but unfortunately its for a PC. Can anyone please help me with this? thank you which article? cos if you can do it on a PC you should be able to do it on a MAC. M. Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 13, 2015 Share Posted May 13, 2015 I do not have a Mac either but I cannot imagine that that procedure would be radically different on a Mac (the procedures would be identical, Macs and PC's both have dialog boxes and input boxes). You change the x and y values of the pattern and texture to resize the appearance of a material on 3D faces. No other method is possible. DJP Link to comment Share on other sites More sharing options...
selectbuilder Posted May 13, 2015 Author Share Posted May 13, 2015 The knowledge base explains using right clicks. So no matter what combinations I try I can't select to copy and even to get its parameters. Link to comment Share on other sites More sharing options...
katalyst777 Posted May 13, 2015 Share Posted May 13, 2015 None of the Home Designer articles are Mac vs PC. The only difference I personally have observed is that Preferences is under the Edit menu on the PC, and under the program menu's name on the Mac, and usually with that one I've seen them actually put both instructions in the same article itself.So, this article should work just fine for learning how to modify a material, such as tile, for it's size as well as rotate it, if needed.KB-00583: Adding Tile to Walls UPDATE: Ahhh, I think I see you're confusion with your statement: The knowledge base explains using right clicks. So no matter what combinations I try I can't select to copy and even to get its parameters. Check out this article on "How to Right Click on a Mac" since you're unfamiliar with the process.http://www.wikihow.com/Right-Click-on-a-Mac 1 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted May 13, 2015 Share Posted May 13, 2015 on the Mac a right click is the same as a left click while you hold the Control Key (CTRL) I believe. 1 Link to comment Share on other sites More sharing options...
selectbuilder Posted May 13, 2015 Author Share Posted May 13, 2015 Yes thank you I'm aware of how to right click on a Mac. So this question will need to be answered by a Mac user. Thank you for trying. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted May 14, 2015 Share Posted May 14, 2015 Problem is nobody understands what the issue is exactly so far , which Tutorial exactly? KB no# ? , cos even if they have a MAC they wont have any idea what to try for you.... more information, pics of the issues ,your plan file etc may help too Link to comment Share on other sites More sharing options...
selectbuilder Posted May 14, 2015 Author Share Posted May 14, 2015 Could someone please explain how to change a tile size? thats basically what I'm attempting to do. Thank you Link to comment Share on other sites More sharing options...
Solution selectbuilder Posted May 14, 2015 Author Solution Share Posted May 14, 2015 Ok I figured it out. changed the size and selected it as my material but it does not change in my view of it. Any suggestions? Link to comment Share on other sites More sharing options...
Kbird1 Posted May 14, 2015 Share Posted May 14, 2015 you probably need to adjust the Texture and Pattern sizes but only a guess these might help http://www.chiefarchitect.com/support/article/KB-00767/8/Chief-Architect/Materials/Creating-a-New-Material.html http://www.chiefarchitect.com/support/article/KB-01006/8/Chief-Architect/Materials/Customizing-a-Library-Material.html http://www.chiefarchitect.com/support/article/KB-00194/8/Chief-Architect/Materials/Changing-the-Direction-of-a-Materials-Pattern-and-Texture.html Link to comment Share on other sites More sharing options...
warrenwest Posted May 18, 2015 Share Posted May 18, 2015 use ' Adjust material definition ' tool and under ' Texture " play with the X and Y values ( scale ) until you are happy with the look. 1 Link to comment Share on other sites More sharing options...
