HomeLinda Posted November 19, 2025 Share Posted November 19, 2025 Hello, I have a weird/crooked dashed line remaining after I deleted a garage and created a carport (see attachment). I can't get to the lines to click on them and delete them. Any suggestions for how to do that? Or if I should not do it because they are important (I don't think they are, but I still consider myself pretty new at this). I am using HomeDesigner 2026. Also... bonus question - there is no Room Type designation for "Carport" so I used Porch and wrote in some text above to state Carport. I've love to do this correctly, is it possible to add a Room Type designation? Thanks! Link to comment Share on other sites More sharing options...
Rookie65 Posted November 19, 2025 Share Posted November 19, 2025 The line above looks like the roof overhang. You can rename any room to what you want by going to the dbx, at the room name, leave the upper name so it defaults, then on the second lane, change it to what you want it to be Link to comment Share on other sites More sharing options...
HomeLinda Posted November 24, 2025 Author Share Posted November 24, 2025 The roof overhang is farther out than this, to the left, beyond the wall, but maybe it's something residual from an old roof or something like that. I'll play with it a little more, thank you for the response. On the room name - thank you, I missed the obvious, I will try not to do that again, and I really appreciate your help!! Link to comment Share on other sites More sharing options...
y-g-m-n Posted November 24, 2025 Share Posted November 24, 2025 delete all roof planes and see if it goes away.. if so then yes a roof plane that extends to give you eaves and not tie into whatever is over carport. got 3d view with roof? Link to comment Share on other sites More sharing options...
HomeLinda Posted December 5, 2025 Author Share Posted December 5, 2025 It looks like it may have been leftover from a camera in 3D view... nothing weird appears in the 3D view though I am going to close the topic, thanks for your help! Link to comment Share on other sites More sharing options...
Solution Renerabbitt Posted December 5, 2025 Solution Share Posted December 5, 2025 2 hours ago, HomeLinda said: It looks like it may have been leftover from a camera in 3D view... nothing weird appears in the 3D view though I am going to close the topic, thanks for your help! It's a roof plane cutting through the rooms ceiling. Either change the roof plane or change the rooms ceiling height Link to comment Share on other sites More sharing options...
HomeLinda Posted December 5, 2025 Author Share Posted December 5, 2025 Got it - thank you! Link to comment Share on other sites More sharing options...
