LancasterLinda Posted June 24, 2025 Share Posted June 24, 2025 Does anyone know if the window casing material can be separated from the window sill? I'm trying to have the casing painted (showing yellow) but the sill remain dark walnut which is original to the structure. TIA. I'm running Home Designer Pro 2025 on an MSI laptop Linda Link to comment Share on other sites More sharing options...
Solution Rookie65 Posted June 24, 2025 Solution Share Posted June 24, 2025 You might try eliminating the interior sill to keep the casing, then use a soffit to make a sill. Then you can make that the walnut color. It's a thought anyway Link to comment Share on other sites More sharing options...
RoyJames Posted June 24, 2025 Share Posted June 24, 2025 One way to separate those materials is to open the window specifications, go to the Sill/Threshold panel, and select a sill from the Library. Once you select one, it will show it separately under the name of the molding profile in the Materials panel. Hope this helps! 1 Link to comment Share on other sites More sharing options...
LancasterLinda Posted August 7, 2025 Author Share Posted August 7, 2025 Thank you Keith & Roy!!! So sorry that I just saw your suggestions. Both suggestions make sense and are do-able. I wish we were notified when people respond. Link to comment Share on other sites More sharing options...
