rurorelroy Posted April 20, 2015 Share Posted April 20, 2015 how would you create this in home designer suite 2016? Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 20, 2015 Share Posted April 20, 2015 The last time I designed a stair lift, I found one at 3D Warehouse, downloaded it and then imported it into my plan file. I do not recall seeing a curved stair one (mine was straight). There is no such object extant elsewhere that I know of. So outside of that, use your imagination. DJP Link to comment Share on other sites More sharing options...
rurorelroy Posted April 20, 2015 Author Share Posted April 20, 2015 sorry i did a poor job of explaining. i have a symbol from the 3d warehouse for the chair. what i need to know is how to create the lift rail along the curved staircase. "use your imagination" is a poor idea given the advantage of this software is to model in 3d. if i wanted to just use my imagination i wouldnt have got the software in the first place. thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted April 20, 2015 Share Posted April 20, 2015 try a curved stair railing altered to your specs for height/panel type etc... Link to comment Share on other sites More sharing options...
Solution katalyst777 Posted April 20, 2015 Solution Share Posted April 20, 2015 If your version allows railings to follow stairs, you could create one with a lower railing height and balusters close together to get pretty close to modeling this. Also, there's a chair lift already available in one of the bonus catalogs. 3 Link to comment Share on other sites More sharing options...
