rurorelroy Posted April 20, 2015 Share Posted April 20, 2015 i am following the instructions creating manual bay windows, but i cant seem to get the window casing to meet at the corners correctly (there shouldnt be any siding between windows), and theres always a weird gap down near the bottom. Help! Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 20, 2015 Share Posted April 20, 2015 In order to approach what you want to do, you need to find a setting in "General Plan defaults" called "Ignore Casing when resizing Doors and Windows" ("Edit - Default Settings - Plan"). This allows you to place windows and doors without making space for the casings of Doors and Windows, it should only be used temporarily to create caseless bay or box manual windows and then turned back off when you are done. DJP Link to comment Share on other sites More sharing options...
rurorelroy Posted April 20, 2015 Author Share Posted April 20, 2015 that setting doesnt make a difference. anyone else? Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 20, 2015 Share Posted April 20, 2015 You are welcome. It does make a little difference but not a lot. I assume you are trying to emulate a bay window unit that is made in a factory as a single unit (Andersen, Pella etc). The only way I have successfully done this is to find that symbol at 3D Warehouse, download it and import it into a plan and then make a hole for it to fit in. Admittedly I did this in Chief Architect Premier and not Home Designer Suite but I am sure you could do something similar provided you do not expect a $60 program to perform like a $2,600.00 program. For the money, Suite is a steal but it does not and cannot do everything under the Sun, Moon and Stars, it is just a fact. DJP 1 Link to comment Share on other sites More sharing options...
Solution katalyst777 Posted April 20, 2015 Solution Share Posted April 20, 2015 Try placing Corner Boards on the outer walls and resize them so that it looks like the casing goes all the way over, covering up the siding where the windows would join together. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 20, 2015 Share Posted April 20, 2015 or make the casing on the windows bigger so they join , the windows are held apart by the required framing ie 2 studs per side.... Link to comment Share on other sites More sharing options...
