dantappin Posted January 23, 2025 Share Posted January 23, 2025 I have a typical garage on the side of the house. The issue is the trusses are automatically running lengthwise (long) vs widthwise (shorter) resulting in some crazy trusses. I know that at the end of the day these will get final custom designed from the supplier - just trying to make this look right and also help with the bill of materials to estimate. I understand roof groups and that sort of helps except that the roof then stops at the end of the garage. Any ideas here besides manual roof panels? Link to comment Share on other sites More sharing options...
solver Posted January 23, 2025 Share Posted January 23, 2025 The auto truss builder was added only a year or two ago and has plenty of bugs. I reported this one long ago. The easiest solution is to draw your own trusses. See help/videos for how to -- it's not like you need to build them from parts, the program does the difficult work. Link to comment Share on other sites More sharing options...
Rookie65 Posted January 23, 2025 Share Posted January 23, 2025 Did you try changing the "framing direction" from the framing dbx? Link to comment Share on other sites More sharing options...
dantappin Posted January 23, 2025 Author Share Posted January 23, 2025 3 hours ago, solver said: The auto truss builder was added only a year or two ago and has plenty of bugs. I reported this one long ago. The easiest solution is to draw your own trusses. See help/videos for how to -- it's not like you need to build them from parts, the program does the difficult work. Yup - probably the way to go. If I set that to a separate roof group it has 90% of the work done and then I just need to re-connect the rooflines. Link to comment Share on other sites More sharing options...
