Match Door Styles?
Designer_Ryan
Go to solution Solved by Rookie65,
4 minutes ago, Rookie65 said:
Use P05
Rookie65,
Sorry, I can't use P05. P09 is the look I have in my current house, and that's the style I'd like to use for this build. I just like the design.
P09 must be the standard builders use. Since I wanted to keep that style I wanted to show the matching bifold doors on my plan.
3 minutes ago, Rookie65 said:
I think P05 is a 3 panel. You won't get 6 panels in that narrow a door for a bifold. Look at the panel door styles and find the 3 panel. It's not rocket science
Sorry by my response. I thought you were wanting me to change the panel door to match the bifold door.
I didn't know you could select a panel door for a bifold door. IT WORKED!
I really appreciate the help.
