AlpineGeoff Posted November 29, 2024 Share Posted November 29, 2024 Hello; Walkout Basement Rambler, with all truss 4/12 roof with some overframe garage roof gables. I have set wall/ceiling elevations, all are correct; yet some walls on front of home are extending to meet trusses which should sit on the top plate. One of of the garages (left one), I keep getting 9 1/4" rafters showing, despite hitting the truss selection button in several different windows. Garage wall top plate elevations are correct. ( Ignore front gable roof on right garage it is incorrect, but I have some wall changes to do there, so I'll correct roof then) What I missing with trusses and wall heights? Thanks, Geoff 1536SF w-stairs & garages & roofs add garage gable 2 ft garage wall flr elv 11-29-24.plan Link to comment Share on other sites More sharing options...
solver Posted November 29, 2024 Share Posted November 29, 2024 35 minutes ago, AlpineGeoff said: What I missing with trusses I don't remember if 2023 auto builds trusses, but you will need to delete any auto generated roof framing -- rafters and ceiling joist, then build trusses. I'd also start by auto building the roof, then refine using the manual tools as needed. Get the roof planes where you want them, then work on framing. Link to comment Share on other sites More sharing options...
AlpineGeoff Posted November 30, 2024 Author Share Posted November 30, 2024 Yes, 2023 does auto build trusses. Program built some, but others remain rafters. I'll delete the roofs and use manual build. Thank you very much for your time! Link to comment Share on other sites More sharing options...
Rookie65 Posted November 30, 2024 Share Posted November 30, 2024 Or just click on the roofs that are still rafters and see if their framing is set to rafters or trusses before you delete Link to comment Share on other sites More sharing options...
