04herrs Posted November 29, 2024 Share Posted November 29, 2024 Before I put my interior walls I added my windows in my basement. However, when I put the interior walls in, it covers the windows. Link to comment Share on other sites More sharing options...
Rookie65 Posted November 29, 2024 Share Posted November 29, 2024 Are the walls along the foundation wall? If so, you create a "pass through" in the wall in front of the window. Depending on the detail needed, you'll likely need to adjust the casing and sill.on the interior or exterior to get it to look right. Possibly even extending the frame of the window. I usually make the pass through about 1/2" larger than the window and center it on the window so there's a bit of a reveal around the edges. Your description is pretty vague as to what you want to do. Link to comment Share on other sites More sharing options...
y-g-m-n Posted December 8, 2024 Share Posted December 8, 2024 for your basement wall make a new wall definition of what you will end up with. Example: CMU on outside or concrete Then insulation foam board then air gap then studs then sheetrock Link to comment Share on other sites More sharing options...
