jasonpoulin Posted November 15, 2024 Share Posted November 15, 2024 Was playing around with roof styles, and the upper wall disappeared. I have deleted the roof, I've deleted all the exterior walls, it will not rebuild the upper wall!!! Not sure how to get that part of the wall to build. Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 16, 2024 Share Posted November 16, 2024 You have probably somehow turned off "rebuild attic walls", so, on the attic level, manually redraw the wall. Link to comment Share on other sites More sharing options...
solver Posted November 16, 2024 Share Posted November 16, 2024 You probably have an invisible attic wall there. Go to the A level and check. Delete the invisible wall and it should rebuild as expected. Link to comment Share on other sites More sharing options...
