Dimensioning and Font Scale
Designer_Ryan
Go to solution Solved by solver,
In AutoCAD I have different dimensioning (and font) scales, depending what size drawings are sent to the layout.
For example, 1/4" scale, small font, used to dimension the house, is 3"
HDPRO has the default dimension as 6".
Is there a way to set up dimensioning scales, so I can just select the scale, size of fonts, I want to use?
  • Designer_Ryan changed the title to Dimensioning and Font Scale
  • Solution
When I bought Pro 10 years ago, one of the ways I learned the program was opening a dialog -- like Defaults. then clicking through each item.
My goal was not to actually learn everything, but instead, I just wanted to become familiar with the program. I tried to remember the terminology -- what things were called, so I could look things up in help, or search online, when needed.
