Seattleite Posted Saturday at 05:42 PM Share Posted Saturday at 05:42 PM Hello, I'm trying to build my U-Shaped stairs in Home Designer Pro 2024. The issue I'm having is that the landing 'floats' outside, between the 1st and 2nd floors. As you can see in the interior photo, the beginning of the landing is aligned with the main exterior wall. In the exterior photo, the yellow arrow is showing the underside of the landing, sticking out from the main exterior wall. The blue line/arrow shows where the floor on the 1st floor is. I have attempted to use the U-Shaped stair tool, but sticking the landing outside of the exterior wall results in a weird floating landing that is not enclosed by any exterior wall: Link to comment Share on other sites More sharing options...
Jo_Ann Posted Saturday at 07:32 PM Share Posted Saturday at 07:32 PM The reason your landing is not enclosed by any exterior walls, is because you have not built the exterior bump-out (walls) that are shown in the pic of the real house. Build the bump-out, and the landing will then be placed inside that bump-out. Link to comment Share on other sites More sharing options...
Seattleite Posted Saturday at 08:37 PM Author Share Posted Saturday at 08:37 PM 1 hour ago, Jo_Ann said: The reason your landing is not enclosed by any exterior walls, is because you have not built the exterior bump-out (walls) that are shown in the pic of the real house. Build the bump-out, and the landing will then be placed inside that bump-out. Thank you for your help! When I build those walls, they connect to the foundation but should be floating. How can this be fixed? Link to comment Share on other sites More sharing options...
Jo_Ann Posted Saturday at 08:57 PM Share Posted Saturday at 08:57 PM Do you think that if you open the bump-out room, and on the structure tab, raise the floor??? Link to comment Share on other sites More sharing options...
Seattleite Posted yesterday at 02:36 AM Author Share Posted yesterday at 02:36 AM On 11/2/2024 at 1:57 PM, Jo_Ann said: Do you think that if you open the bump-out room, and on the structure tab, raise the floor??? Unfortunately I can't seem to select this as a room When clicking on the stair landing then hitting tab it goes: Stair landing -> Wall -> Room (in this case, the entire main floor) Is there a way to somehow define this as a room? Link to comment Share on other sites More sharing options...
solver Posted yesterday at 02:45 AM Share Posted yesterday at 02:45 AM 1 minute ago, Seattleite said: Is there a way to somehow define this as a room? Just like you would define any room -- with a wall. Link to comment Share on other sites More sharing options...
Jo_Ann Posted 22 hours ago Share Posted 22 hours ago Did you delete the original house exterior wall, where the stairs meet the landing? Link to comment Share on other sites More sharing options...
