Designer_Ryan Posted April 25, 2024 Share Posted April 25, 2024 How can I just remove the tile, so the wall is back to drywall? I've added tile to a wall, but if I use material eyedropper, then material painter, all it does is change the color of the tile. Bathroom.plan Link to comment Share on other sites More sharing options...
Rookie65 Posted April 25, 2024 Share Posted April 25, 2024 Try opening the wall and then changing the materials Link to comment Share on other sites More sharing options...
Designer_Ryan Posted April 25, 2024 Author Share Posted April 25, 2024 I did try that. When changing the wall material, it adds a line "of the material" through the middle. Link to comment Share on other sites More sharing options...
Rookie65 Posted April 25, 2024 Share Posted April 25, 2024 Maybe delete the wall and redraw it then. Did you change the materials in the wall dbx, or use the paint tools again? Link to comment Share on other sites More sharing options...
Designer_Ryan Posted April 25, 2024 Author Share Posted April 25, 2024 I added it to the wall by clicking Material Painter and applying. I couldn't just undo it, as the file had been closed and reopened. I figured out how to get it removed by looking more into Wall Specification, Materials. I originally selected Wall Specification, Wall Covering. By choosing the Wall Specification, Materials, the Interior Wall Surface Said, "No Change." So, I selected it and changed it back to Drywall. Success! Thanks for your help. 2 Link to comment Share on other sites More sharing options...
Cobraahsta Posted May 26, 2024 Share Posted May 26, 2024 On 4/25/2024 at 6:55 PM, Designer_Ryan said: I added it to the wall by clicking Material Painter and applying. I couldn't just undo it, as the file had been closed and reopened. I figured out how to get it removed by looking more into Wall Specification, Materials. I originally selected Wall Specification, Wall Covering. By choosing the Wall Specification, Materials, the Interior Wall Surface Said, "No Change." So, I selected it and changed it back to Drywall. Success! Thanks for your help. Hey, so does it mean it's better not to use Wall Covering? Or did you later reapply Wall Covering? Link to comment Share on other sites More sharing options...
Designer_Ryan Posted May 27, 2024 Author Share Posted May 27, 2024 I fixed the problem. I just re-drew the wall. Link to comment Share on other sites More sharing options...
y-g-m-n Posted May 27, 2024 Share Posted May 27, 2024 wall covering is meant for wall paper or maybe rooms with different horizontal colors. like tan from chair rail down and off-white above. Tile on wall should eb done with CUSTOM BACKSPLASH so you account for thickness OR make a NEW WALL DEFINITION with tile being applied to drywall or backer board or the orange Dietrich water proof membrane. Probably other ways to cheat system and make pretty 3d models - as there are a lot of flat objects you can stick onwall and change thickness and material to be tile. flat mirrors, cabinet partitions, 3D shapes on and on. but I think custom backsplash is best Link to comment Share on other sites More sharing options...
