ChiefRichMD Posted April 16 Share Posted April 16 I have HD Architectural 2024 and am trying to build out my raised ranch basement as concrete roughly 44" high and then framing - siding on the outside and drywall on the inside. I can't seem to find how to do this. I even looked in foundation defaults, but I didn't see an option to do this such as using a pony wall - if that is what I should do. I'm not an architect obviously. How should I do this? Link to comment Share on other sites More sharing options...
Rookie65 Posted April 16 Share Posted April 16 Pony wall is how you do it. I don't know if Architectural has that option. If not, you may want to consider upgrading to Pro. 1 Link to comment Share on other sites More sharing options...
ChiefRichMD Posted April 16 Author Share Posted April 16 1 minute ago, Rookie65 said: Pony wall is how you do it. I don't know if Architectural has that option. If not, you may want to consider upgrading to Pro. Thanks @Rookie65Architectural does have 3 different kind of Pony Walls - straight, curved, and straight glass. I just don't see how to change my foundation walls to that type. Could architectural support that wall type but not for foundation walls? Link to comment Share on other sites More sharing options...
Rookie65 Posted April 16 Share Posted April 16 Check help or your reference manual 1 Link to comment Share on other sites More sharing options...
ChiefRichMD Posted April 16 Author Share Posted April 16 26 minutes ago, Rookie65 said: Pony wall is how you do it. I don't know if Architectural has that option. If not, you may want to consider upgrading to Pro. Thanks @Rookie65Architectural does have 3 different kind of Pony Walls - straight, curved, and straight glass. I just don't see how to change my foundation walls to that type. Could architectural support that wall type but not for foundation walls? Well, I can delete each wall after creating the foundation and then draw a pony wall in it's place. There just doesn't seem to be a way to specify that type when building the foundation. Additionally, I can select any foundation wall and open the dialog and change to almost any other type - just pony walls aren't an option. Anyway, deleting each and recreating as a ponywall is not too hard. I also changed the pony wall default to match what I want. It just seems like kind of a bug to allow the functionality but make it "look" like it isn't an option for a foundation wall. Link to comment Share on other sites More sharing options...
Jo_Ann Posted May 4 Share Posted May 4 You have hijacked someone's thread. Please delete this post, and start your OWN thread. Link to comment Share on other sites More sharing options...
